Why is the logo not visible from the back side of the transparent glass?
Anybody knows how to figure this out, thel logo is not visible from the back side of the transparent acrylic
I made more refractive index
This might be a simple thing but is the texture set to “two sided”?
Activate the option “two sided” and you’ll see the label
I‘m afraid we don’t talk about the same thing, what I thought is to see the logo through the glass, not just label on the backside, I hope I’ve made me clear.
This is the effect when I click on two side button, I think it is unrealstic, because we can’t see the logo from the front as there is no logo at the back side of glass.
Then I add a plane in front of the blass and connect the label to the opacity pass of the plane.
It seemed to be what I want.
The effect you described depends on the depth. If you use a tiny value instead of 0 (= infinite), you’ll get this result.
Hope that helps
CheerEO
Marco
PS: this topic with labels is discussed several times in this forum.
Thanks, it really helps
